Page 18 of 58 FirstFirst ... 8161718192028 ... LastLast
Results 171 to 180 of 580
Thread: Discover Media retrofit
  1. #171
    Quote Originally Posted by c0stinn View Post
    Hello, kamold!
    Is there any way to check if cp is active or inactive for a mib2 unit? If there's CP active, can i disable it with any tools or sd card software instead of going to vw dealer? I had an issue with my rvc as i told you and when i went to vw dealer they told me that the camera wasn't installed by them and they don't even want to look at my car, even if it's retrofitted with OEM equipment. I don't want to go there again for the CP to tell me the same thing because they will make me angry.
    When CP is active there is a message on the screen and it is also seen in diagnostics software
  2. #172
    Oct 2018
    Poland
    Cool Discaver Pro
    Dobry dzień.
    Mam Octavię II FL 2010
  3. #173
    Oct 2018
    Poland
    Jul 2018
    Canada
    I love my retrofitted MIB2 radio in my Passat. There is only one issue I've been having as of late. Whenever it is 2 degrees or lower (Celsius) the rear camera flakes out. When it was a little warmer, it would be black screen when I started the car first thing in the morning and on the way home (5pm so warmer out) it would be working just fine. The camera is original, and would always work, so thinking it is wiring into the MIB or the retrofit adapter for the RCA cable. Any thoughts or ideas to troubleshoot this one?
  5. #175
    If you have original camera I'm guessing you are using an RGBS to CVBS converter? They can be a bit hit and miss. You can replace the camera with a cheap aftermarket composite camera and go straight into the Discover media and get a better picture.
  6. #176
    Dec 2018
    Wahroonga
    @kamold,
    I have been reading your posts here with interest. I have a Mk6 2012 R that has RNS510, dynaudio, Reverse camera and bluetooth factory fitted. I am interested in upgrading to the Discover Media system but don't have the skillset or time to complete the upgrade. Wondering if you offer this service and can supply parts. I'ld like to replicate all functionality with the current setup with the addition of Carplay and DAB.
    Andrew
  7. #177
    Dec 2018
    kujawsko-pomorskie
    Park Distance Controller
    Original module 3C8919475 HW07 SW007.
    This works fine for PDC display on its own however it won't allow the reverse camera image with the PDC overlay on the left hand side. This needs to be replaced with a newer 1k8919475b. This also requires an adapter wiring harness as the connectors changed.
    Hi I have retrofitted RCD310 to Discover media 5c0 035 680C mib std2 pq35 + navi. I have the same sympthoms for RVC (when tailgate open, OPS visible and icon gray, when tailgate closed rvc video visible but without OPS and without icon on left toolbar). Images here OneDrive . I would like to ask you, did you have to replace your sensors or not?
    I have 1k0 ... 475K bosch pds module and 7L5 919 275B sensors.
    Do you know if I can replace covers and sensors keeping my bumper with current holes? Does diameter of hole is different or the same for both sensors? I know that sensors has different construction, but using rubber o-ring with cover from scirocco 2015 or jetta could do the work?
  8. #178
    You don't need to replace the sensors, just the PDC module.
  9. #179
    Dec 2018
    kujawsko-pomorskie
    Are you sure that Bosch sensors will work with Valeo PDC? Guy in carsystems.eu said that Bosch sensors have different harness than for Valeo. They can help with reassign pins to new plugs when I will buy PDC from them, but in case that sensors were also valeo. I know that I can connect Valeo PDC 1k8, but I do not know if Valeo sensors has more or less wires than Bosch.
    Also I wonder if parameters for different sensors will be ok to work correctly. I think that the fastest way to check if 1k8 will work with my Bosch sensors will be plugging adapter to new unit without removing anything from car.
    Quote Originally Posted by lunghurts View Post
    I have both so maybe I also would be able to help you with this.
  10. #180
    Jan 2017
    Quote Originally Posted by moda View Post
    Nice one Kamold Would you mind giving a breakdown of the part numbers etc if we wanted to do this ourselves? The hardware modification for the component protection sounds like it's the trickiest part.
    How does it compare with the Composite Media (~$1k with component protection removed) and RCD330 Plus (~$200-300) units?
    Don't touch the RCD330 unless you're after a budget install. The sound will be a downgrade from your factory unit (depending what you have), and you'll forever find bugs. I pulled mine out after a little over a week and went with a Composition Media install.
    CM vs DM is at a very basic level a choice between Sat Nav or not. I went CM, because no on-board navigation really compares with Google Maps, so there was not point paying extra, when everything you need comes with Android Auto / CarPlay.
    Installation wise, everything was pretty straightforward with CM, albeit not quite as straightforward as an RCD330
