Results 1 to 10 of 1488
Thread: ANS-810 / ANS-510 (PROPER RNS-510 alternative)
    Jan 2011
    Possibly so - I just find it a tad annoying but yeah it's probably the polarization. Quick glance over the top of the sunnies does the trick.
    Aug 2007
    For those of you (like me) who are overwhelmed by the gazilions of options available in the NAV software, I found a manual for the IGO. I don't know if it's for the same version we have, but it looks pretty similar.
    http://www.hemanavigator.com.au/manu...-UserGuide.pdf
    CW MY12 5Dr manual GTI. ANS-810 head unit.
    May 2012
    Installed the headunit, I'm getting really bad static at the moment, any ideas on what I can check? When I press the Dimmer button, static is louder on the low setting than the high setting. If I press the Dimmer button so the screen shuts off, the static goes away.
    Jun 2011
    Quote Originally Posted by prince View Post
    You mean static like cracking noises in the audio? Does it happen on both radio and SD / USB?
