Results 1 to 5 of 5
Thread: after market head unit
    Apr 2008
    Perth
    hi guys.
    new to the whole aftermarket stereo thing.
    just wondering what peoples thoughts are on a single din fold out alpine head unit.
    most probably this one
    http://www.alpine.com.au/products/pr...sp?modelID=383
    i can get one off ebay for a fair bit cheaper.
    thanks
    Kiel
    Feb 2008
    Auckland NZ
    these are very nice unit's.
    If i'm not mistaken they have a optical output?
    You would most likely want to add a alpine RUX-C701 and H701 EQ with this combo.
    Something else you need to double check if you getting it from Ebay US. Is that your radio frequencies will work. the US frequency ranges, are 86.1 to 107.3. the use the odd numbers not even numbers.
    Audi S4 (2001) - Imola Yellow
    Secret Project
    Apr 2008
    Perth
    thanks.
    this is from hong kong. and all the radio frequencies are made to work in australia (advertised on ebay aus)
    and yes they do have a digital optical output. is that the optical cable like i have in my ps3? advantages disadvantages?
    just found some SPX 17 PRO for $599 worth it?
    Feb 2008
    Auckland NZ
    ok again hong kong have different range, there radio's go from 78.3 - 90.1
    So please just make sure.
    Regarding optical, yeah same kind of cable as your PS3. Advantage, Pure digital lossless signal to your processor than if you can find an amp that does not cost the earth with optical in you can use that.
    As for the new SPX pro's yeah for $599 seems to be a pretty good deal.
    Again double check, these days apparently around 75% of all electronic gear on ebay is knock off's, not the genuine. If the gear is real like you are saying, then yeah both appear to be a very good idea.
    Secret Project
    Apr 2008
    Perth
    yea i will definately be making sure b4 dishing out a few grands worth
    thanks for ur help.
