Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: VW504/507 oils available from...
  1. #21
    Jan 2009
    There is not much of the differnce between VW504.00/507.00 approved oil, if any? At least to the engine.
    I wouldn't think so either, since performance as a variable can be eliminated, due to VW's in-house oil standards and approval procedures.
    Hence, that gives you the freedom to direct your money to your lubricant manufacturer of choice.
    EDIT - heh, unless of course, your lubricant manufacturer of choice doesn't make 504/507 oils.
  2. #22
    Aug 2011
    Canberra
    Thanks for the response Transporter. He also told me he did the Haldex filter himself.. Apparently it's about 500 buck he told me. Going from a 94 Civic to a Golf, I'm not sure what to expect and whether I should get it checked out.
    So what is the preference? Penrite or Lm Toptec? Both around the same price, but if anyone prefers one over the other, would love to hear about it.
  3. #23
    Adelaide hills, SA
    Quote Originally Posted by Kid Danny View Post
    As Diesel_vert said, it's pretty much your choice. But if you couldn't make a decission, then go with LM.
  4. #24
    Aug 2011
    Canberra
    Sounds good. I will grab that. While I'm at it, any preferences for coolants? Did a quick search, but nothing really popped up...
  5. #25
    Adelaide hills, SA
    The VW coolant is not expensive, so don't get tempted to use something else that will most likely corrode or cause leaks in the cooling system. Change the coolant in 4th or 5th year and then every 2-3 years.
