Results 1 to 4 of 4
Thread: Potential Issues with Waterless Engine Coolants
    Jul 2014
    London, UK
    Present: Superman BMW F30 330d M Sport + Toys
    Ordered: Red Tornado VW Golf Mk7 R 5 Door + DSG + Toys
    Adelaide hills, SA
    Not a problem for VAG engines they don't use the waterless coolant.
    The ethylene glycol coolant mixed with water up to 60:40 ratio are actually increasing the boiling point of the coolant mix and when the coolant reservoir pressure cap is working properly, it will raise the boiling point above or close to 120deg.C (it varies between the brands of coolant, I've seen some claiming 160degC).
    Use water mixed with some aftermarket magic as a coolant in your engine at your own peril, you will regret that later.
    Oct 2010
    Melbourne, VIC
    I found the Cetane additive article on that site quite interesting. Shame that it ends in an advert, though.
    Resident grumpy old fart
    Jul 2011
    Thanks for sharing this info VW7R.
