Page 15 of 100 FirstFirst ... 513141516172565 ... LastLast
Results 141 to 150 of 997
Thread: Wreck to Race.
  1. #141
    Jun 2006
    Orange NSW
    Another parcel from GermanAutoParts!
    I should have enough bits now to get it running again over the long weekend.
    Pete
    Nice 8v cam timing sprocket. I made my own instead of buying one.
    Good stuff pete, hope you get it humming again soon!
  2. #142
    Oakleigh VIC
    My simple machining skills aren't quite up to that yet.
    This one is pretty neat but seems a bit heavy @ 528 grams
    It's a standard sprocket with the spokes milled out and the new center fitted.
    Here's the flip side FYI.
    Pete
  3. #143
    Oakleigh VIC
    Things took a bit of a detour when i was putting everything back together yesterday. The new radiator I bought turns out to be a Mk 2 one.
    Well fair enough I figure it is a MK 2 motor after all, so I set about making it fit.
    The mounting holes were easy, the studs line up with a couple of captive nuts that weren't used, so I drilled them out.
    Thhe bigger problem was that I didn't realise that a MK 2 radiator is about 2 inches wider than a MK 1 radiator.
    Ladies and Gentlemen I give you the MK 1.5 Fan housing!
    Pete
  4. #144
    Aug 2005
    Great stuff Nice choice with the Eurospec gear - they make really tidy gizmos
  5. #145
    Camden, Sydney
    That fan shroud is pretty neat Pete. VW Just used a bit of mecanno to stretch out to the boltholes. Yours will probably cool more.
  6. #146
    Oakleigh VIC
    Yeah, I considered doing that too, but I'd just filled the oxy bottles and I had a spare fan housing lying about.......
    The mecanno would just have annoyed me 'till I did some thing like this anyway.
    Pete
  7. #147
    Oakleigh VIC
    It makes noises! Well at least it did until it made the really loud noise!
    I took a while to get the injectors bled and then it fired up no worries.
    I'd given it a few 5 minute runs while I checked for leaks and twiddled with the dizzy.
    As I was rotating the dizzy I heard an almighty crack and saw a big flash and promptly removed myelf from the general area. I thought I'd stuffed the dizzy at first. There was a strong smell of electrical burning.
    Upon investigation I have blown apart the temperature sender!
    I must have got some wiring crossed up somehow and the thing has had a meltdown, it blew the guts right out of the sender! So much for fuses!
    Hopefully it hasn't taken out the voltage reg in the dash.
    Any body got a spare 2 pin sender?
    Time for lunch and a bit of a think about the situation now.
    Pete
  8. #148
    Oakleigh VIC
    Lunch is over - time to go break out the multi-meter!
    Pete
  9. #149
    Oakleigh VIC
    Ok a few wiring gremlins sorted.
    I'm not sure why the temp sender blew. I didn't think they were polarity sensitive, but That's all I can think of at the moment.
    There's an un used MK 2 temp sender on the underside of the water inlet to the head. Can anybody confirm that this actually a temp sender and how it's wired? If I can hook this up instead of the MK1 sender on the head outlet it might save me some grief trying to find a new one.
    For some reason the fan wasn't kicking in. Turns out there was no fuse in the fuseholder I don't remember removing it! I put new connectors on the wiring at the fan switch and replaced the fuse and it's all good now.
    I took the car for a spin around the block, still needs tuning. You can feel the cam start to work at about 3.5K. I think I need to advance the timing a heap more.
    I feels a bit warm in the engine bay but it hasn't been going at any speed yet so that's expected. It needs a good run now to boil off the last of the coolant that found it's way into the motor when the head gasket went south.
    I might wait until next weekend to tune it on the road, it's still in race trim and the local police seem to have a blitz on this long weekend. Once it's back in Grandma's shopping trolley garb I'll attract less attention.
    Pete
  10. #150
    Jun 2007
    Eastern Suburbs Melbourne
    Yep. Long weekend = double demerits! bummer if you got caught.
    Good to hear you've got in running and fix after it broke after you fixed it.
    i like volkswagens
