Pebbles is now rolling with 5 speeds. Scored a cordoba gearbox with the right ratios, complete with flywheel and clutch. If anyone wants to do this swap, you will need to fab/source a gearbox mount, grab the 15 tooth (usually red) speedo drive gear (just pull it off the end of the cable) and the sandwich plate and covers. Also, either swap the 100mm drive shaft flanges for a set of 90mm flanges or else, mod your drive shafts to accept the 100mm inner cv joints off the cordoba (they are thicker than the 90mm cv joints so the shoulder on the mk1 drive shaft needs to have the difference machined off it). I had a set of 90mm flanges so i swapped them and replaced the seals while i was at it.
Beige 79 Mk1 GLD White 76 Mk1 LS 3 door
White 68 Alfa 1750 Berlina Champagne 91 Alfa 75
Red 09 9N3 Polo TDI White 2010 Skoda Octavia Combi TDI
