Results 31 to 35 of 35
Thread: Operation Rescue Chair
  1. #31
    Point Cook, Vic
    temp sits smack bang in the middle
  2. #32
    Jun 2007
    Eastern Suburbs Melbourne
    injectors clogged up here?
    something worn/damaged along those lines, cause of continual usage of crappy fuel perhaps?
    Just spit balling...
    i like volkswagens
  3. #33
    Point Cook, Vic
    always been run on premium fuel. Had been sitting under a tree for almost 12 months though prior to me getting it running again. It did have one of those emergency fuel caps though so fuel contamination could be an issue i guess.
  4. #34
    Aug 2007
    so is it ****ed again??
  5. #35
    Point Cook, Vic
    yeah its still causing issue!
    We are suspecting some sort of electrical problem somewhere.
    problem is as follows.
    on cold start the spark is too advanced. So the engine spins backwards!
    If you retard the timing it starts fine but then you need to set the timing back to where it should be for the car to run properly. Once you let it run for 1 minute. It will start fine each time until you let the car get completely cold again. Then to get it started again you need to retard the timing. Whilst the car is timed right it runs really well with heaps of grunt
    What we have checked or swapped out for known working parts are listed below
    timing has been checked and quadruple checked
    ecu
    dizzy/hall sender
    entire throttle body and all the sensors that hang off it and the injector
    temp sensor
    One thing i havent tried swapping out yet is the coilpack. Is it possible for one of those to play funny buggers but only when the car is cold or under starting load? Im really starting to expect some sort of weird electrical gremlin!
    car is great as a day to day driver just you need to keep a 13m spanner in the car to get her started hehe. hard to spend a lot of time working on it whilst i have so much else going on!
    FOLLOW US ON FACEBOOK
