OK, I just had a look at the linkage with someone moving the shifter from side to side. (Definitely not cables, by the way).
When the gearstick is moved side to side, the shaft that comes out of the firewall, and through a plate is moving side to side about 1cm. It looks like we have a worn/broken plastic bushing at that point. (I'm assuming that the shaft should only rotate and move back and forth at that point?)
Is this an easy fix???
Thanks for the help!
Rick
1996 SEAT Ibiza GTi
1970 Porsche 914
1956 VW Beetle
