Results 1 to 7 of 7
Thread: Window problem..........
    Sep 2014
    So windows in my vr6 are all working fine i prk the car come back 1 hour later and none of the windows work at all not the front or back!
    Not a fuse problem cause i checked and i dont think all 4 window regulators would go bad at the same time. Anyone come across this problem.
    Ohh and everythin else works fine all the lights swithes side mirrors radio etc...
    put your key in the door.
    turn it to unlock and hold it. see if any of the windows work.
    this will rule out window regs and may point to a problem window
    im having similar crazy issues atm
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Sep 2014
    Yeh i tried that and no window opened.....
    Jan 2010
    wow thats really weird, i have the same issue all of a sudden, thinking it was a reg, i took a reg out of the door and its working intermittenly out of the door = even stranger....
    Do the window switches light up when you turn the lights on
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Sep 2014
    Yeh all the switches light up i think a wire made contact from melting in the hot weather im gonna have to check that all out
    keen to see what you come up with.
    I had similar.
    no windows, no mirrors. fuse looks fine (even swapped it to be sure), switches have lights
    windows work via key.
    replaced both rear door looms as I know they were pretty had it.
    still no chop
    currently got the dash apart (again... 10th time...?!) chasing other things plugged into that same bunch of wiring/relay
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
