Results 1 to 10 of 13
Thread: VR6 Compression Testing
    Nov 2010
    sunshine,vic
    Good to be back after a little getaway from the Golf
    Im only 2 days from getting my license back so I decided to do a Major service on My golf vr6 .
    Today I have pulled out my spark plugs and they were rusted on top but superclean where it fires up .}
    Also I have done a Cold engine Compression test on each Cylinder @ 3 seconds each and my Reading were Off The Gauge
    Gauge Meter 0-200 LB / 0-14 Kg
    Readings were all the same :
    360 degrees all around the gauge untill stopper Needle which = roughly 300 LB
    I dont think a MK4 Head gasket would Cause this .
    engine is very responsive not that im complaining but it just annoyed when I couldnt get a reading .
    94' Golf Mk3 Vr6
    Aug 2012
    Kangaroo Valley, NSW
    Maybe you just have a God engine.
    Jun 2011
    Vr6's 'new' limit is 180-190psi.
    Aug 2012
    Is you engine running any other modifications. Maybe your compression test went weird.
    Nov 2010
    sunshine,vic
    only a MK4 vr6 headgasket and a rebuilt head and shaved down but that would not cause compression to go higher because the chamber is in the block
    i tried the compression tester on another engine and it was fine .
    my vr6 is almost 300 psi
    the engine is dead cold which would mean that the rings would not have expanded .
    im just getting Hi compression the is the gauge reading
    and Dyno Sheet
    94' Golf Mk3 Vr6
    Jan 2011
    Rooty Hill, Sydney
    3 seconds
    Umm try it again but give it Only 2 or 3 turns.
    The important bit is that they all give the same reading !
    Garage:
    VR6
    XR6
    R36
    Nov 2010
    sunshine,vic
    There all the same the needle jumps to 170on 1st then 230ish 2nd an keeps going untill it hits the needle stopper
    Jun 2011
    Get down to supercheap buy a other one, use it, then see what happens. Then take it back and say it doesn't fit,
    Nov 2010
    sunshine,vic
    Yeah thats what im thinking of doing thanks
    Nov 2010
    sunshine,vic
    Anyone going to " I love Vw " in March ? Hopefully I Am with the Golf slapped and the Kerschers On Cant wait to meet You guys
    Also Found my Cat was blocked thinking of a mandrel bent bolt on 2.5" exhaust before ILVW .
