Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: Vibrating Noise
    Sep 2006
    Australia?
    Exclamation Vibrating Noise
    Hey all dubbers,
    I have a problem with my front left wheel. When the car is in motion it vibrates I have no idea. Me and my dad checked out the wheel on Saturday, thought it might be the adapter but it wasn't. When the car is rolling forward or even going at about 80khm, it still vibrates abit. When I put my foot on the brake it stops making the sound
    I have no idea what it could be, can anyone help me.
    syncro Guest
    Tyres gone pear shaped?
    Sep 2006
    Australia?
    Quote Originally Posted by syncro View Post
    Nope can't be there only one week old
    gpk_gti Guest
    warped disc or pads are worn out.if you apply the brakes and it stops ,its the brakes im sure!! also,did they balance the rims/tyres??
    syncro Guest
    Quote Originally Posted by Mk3vr6 View Post
    Manufacturing defect? Bolts loose?
    Try swapping the wheels around. See if the problem moves.
    gpk_gti Guest
    because you have moved the center of gravity out(spacers)now you have excentuated the problem.
    Point Cook, Vic
    when discs are warped u can usually feel it thru the brake pedal when u press it.
    Perhaps its just something simple like a wheel weight that has come off and the wheel is now out of balance. id take it back to the place that did the install for u and ask them to check it.
    FOLLOW US ON FACEBOOK
    Sep 2006
    Australia?
    Quote Originally Posted by gpk_gti View Post
    I have not done an alignment yet, have not had the time. But the wheels are balanced.
    I will Tomorrow morning I'll get a wheel balance done and ask them.
    It stops when I apply the brake. Its annoying.
    Feb 2007
    im a pom from the UK, but am living in Oz for a while...
    have you checked to see that the bolts are not loose, all it takes is for one bolt to be loose and it will vibrate like that...it happened to me on my mk2
    syncro Guest
    Sounds like a loose wheel to me.
    When I get new tyres, I just take the wheels to the tyre shop as I don't let them touch the car. But I'm paranoid!
    (Tyre fitters are generally pretty low on the evolutionary chain)
