Results 1 to 6 of 6
Thread: VAG-COM in 1994 VR6
    Jul 2012
    VAG-COM in 1994 VR6
    hey just wondering if this cable will work in my 1994 VR6 with OBD1 even though the ad says OBD2. is there a difference? im running VAG-COM 704.1
    Gosford Central Coast NSW
    not sure.... VAG COM is a rip off these days, since the OG VAG COM changed their name to VCDS because (IIRC) of some legal implications with Volkswagen Group.
    You might be better off borrowing a genuine VCDS cable, or visiting someone who has one.
    I have used a genuine VCDS cable on a 95 Toledo with good results.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Jul 2012
    so it has to be the right cable for the car?
    so i might just have to buy a genuine VAG-COM/VCDS cable?
    or get someone else to do it.
    Dec 2006
    Kilsyth, VIC
    The knocks off's use an old unlicensed version of VAG-COM and can't do "everything"... like clearing error codes has to be done module by module where the full version will do it with one click.
    There isn't much to code/change in the 94 models, just reading error codes really.
    So in reality a $25 eBay knock off will do pretty much everything you want., so you're probably better off with one of those hand held code scanners.
    Jul 2012
    well ive got the VAG-COM 704.1 program just not the cable, which is what i was asking about.
    Jul 2009
    I use that exact same one with the free vcds program. Reads all the fault codes and can clear. I've got a '94 as well.
    '94 3dr vr6
