Quote Originally Posted by SpeciP3 View Post
Timing chains like belts are prone to wearing and if they done break it'll be an expensive rebuild number. Also when finding out about the timing chain ask about the guides, these wear and are also expensive.
As said above heater core often fails and takes a while to replace or else is costly to have replaced.
I'm not on the mainland, but have accident history and got a few quotes here and there, shannons was about $600 with the car insured for $10k, which was not bad. BTW the online quotes are often far more than excessive than if you ring up.
cheer buddy, ill get in contact with the guy,
and another thing, the dude mentioned that the springs may need replacing soon..
wat would you guys recommend and how much do they cost?
