You said fast.. rest are all broken
Printable View
Broken! :lmfao: :lmfao:
I said fat ass though, as in they weigh to much :P
Okay so got a bit of work done today.
New rear main seal:
http://www.vwwatercooled.com.au/foru...wc9sjr9i-1.jpg
Flywheel on and torqued:
http://www.vwwatercooled.com.au/foru...aj29rvve-1.jpg
Clutchnet stage 4 disc and pressure plate:
http://www.vwwatercooled.com.au/foru...kzzmxmhq-1.jpg
New water pump:
http://www.vwwatercooled.com.au/foru...kohhosia-1.jpg
http://www.vwwatercooled.com.au/foru...tmpstqte-1.jpg
Deleted A/C and installed new accessory belt:
http://www.vwwatercooled.com.au/foru...75pnyknz-1.jpg
Thermostat housing fitted:
http://www.vwwatercooled.com.au/foru...6gfxqso9-1.jpg
Cleaned the oil filter housing it's nice and clean now inside:
http://www.vwwatercooled.com.au/foru...j3essrlx-1.jpg
http://www.vwwatercooled.com.au/foru...mgkdpiiq-1.jpg
Exhaust gasket installed with new hardware:
http://www.vwwatercooled.com.au/foru...umrk1oob-1.jpg
Also added the turbo oil return line and welded some 3mm plate to the sump bottom for scrape protection then fitted it.
Next step is to install the intake manifold and gearbox.
Tim.
Got the Mig Fab short runner intake installed with billet fuel rail as well as 10mm ignition leads. Starting to look the goods now:
http://www.vwwatercooled.com.au/foru...jlxfd3xx-1.jpg
You'll need to massage the inside of the gearbox to clearance the rivets on the pressure plate.
I used a flapper wheel on a 4" grinder.
Suggest getting a pinion brace too.
Looks the goods
:banana::banana::banana::banana::banana:
**** this motor is looking amazing! dibs first ride along when its done!
Keen for screamer pipe
Thanks Hayden I'll see if it spins a full rotation when the gearbox goes and if not I'll give it a grind to get it to fit!
Already have a pinion brace I'll put it on soon once the gearbox is ready to go on ;)
Haha thanks Simon it's getting there!
Screamer maybe after it's engineered and road worthy haha
Installed a TiAL MV-S 38mm V-Band external wastegate:
http://www.vwwatercooled.com.au/foru...o3lmfeva-1.jpg
I think I'll set the springs to 1.5 or 2 bar pressure resistance depending on what peak boost pressure is decided upon.
