Have you had an alignment? If you have and it still feels loose, jack up the front of the car and for each wheel, hold on to the 3 and 9 o'clock positions and see if there's any play. If there is, the tie-rod might need replacing. If there's also excessive play at the 12 and 6 o'clock positions, it could be your wheel bearings or lower balljoints. If you can, look at those parts while you're moving them.
Didn't know you installed a supercharger in Mark, looks good, and I bet must sound and feel even better! Can't help you with your engine issues, though someone else will chime in.
