Good work!
Good work!
Lollllllll
Sent from my GT-I9300 using Tapatalk 2
haha, work man! i'm jelly as **** at your vr swap....I miss the six.....boo
Why you jelly alex? Just do it... was the easiest swap ever! Plug and play!!!!
mmmmm.......
in other news, I missed the post where you said wheels! so keen for non steelies dude
:edit: also, man is yours a hydraulic roof and does it work? if so then whats the procedure you have to take to make it work? I found out the other day that I need to switch to ignition and then back off again, and then hit the switch?? all i've ever read is to just switch it to ignition? so my junk has always worked :/ I now have spare pumps, switches and relays.... haha
Stu will swap the engine FOC including loom
