Probably going to be way too much effort.
Why not just get some high output/throw halogen bulbs?
Well guys i need new headlights and i really want to run HIDs but its illegal unless they are self leveling and they are annoying to other drivers if they are not aswell...
What are my options?
Can i make them self leveling or can i buy mk4 ones and make them fit??
Stu
Yeh i gues i can do thatbut i was just wondering because HIDs last quite a long time and overall better!
Whats equivalent to a 5000k?? that is bright??
I would look into some osram bulbs.
You would have to check what bulbs you have obviously and compare these to other halogen bulbs.
Phillips and Osram would be the way to go though.
You can actually buy self levelling headlights from tmtuning! They are OEM aswell but you have to make them work. I wouldn't be too fussed to be quite honest, If you make them right the first time you will never get done, I had them on for 6 months and they were absolutely fine!!!
So if they are set right the first time then they should be ok??
Found them!! rheostat leveling kits
Yep thats right I don't see why not![]()
It's projectors you need if you want to run HIDs isn't it? Doesn't have to be self-levelling if you've aimed them correctly (which should be done if you retrofit projectors properly).
Please stop for a bit and do some research before you screw things up royally - if you don't understand what you're buying, you'll only get it right (if indeed you manage to do so) by sheer dumb luck.
For what it's worth, 5000K refers to the colour (or technically, colour "temperature" - basically, the colour of the light that a matte black object will output when heated to a temperature of 5000K, or something just over 4700șC) of the lights, and not their brightness.
Those allow for manual adjustment (using a thumb-wheel in the cabin), but not the automatic levelling which is required by the ADRs.
Nothing to see here...
