Results 1 to 10 of 14
Thread: Problems finding 1st
    Jul 2011
    Footscray, VIC
    Hi all,
    Have a bit of a gremlin with my '96 GL that I wanted to share and get some ideas on:
    I'm having problems shifting to 1st from neutral, especially when parked. I'll try my usual shift style (pushing left then forward) and it feels like the stick's hitting an invisible wall. After lots of wiggling around or a slight modification to my shift (e.g pushing diagonally left and forward at the same time) I'll eventually wrestle it into first.
    What's weird though is that I don't normally have to mess around like this when I'm driving. It seems to give me less resistance if I'm changing to first after stopping at an intersection for example.
    I've heard that the linkages can go, or that there may be some kind of adjustment that can be done. Any tips on how I can check this? Just want to make sure I know a bit about the possible issues before I head off to a mechanic (and get told that I need a gearbox rebuild or something horrid like that).
    Apr 2010
    coogee NSW
    Just go straight to second! Haha
    Just kidding! Sounds like worn synchro's!
    R36 Twin Turbo Golf 650hp 0-100 3.1sec 11.106@125mph.
    Oct 2006
    Quote Originally Posted by BJ maximum View Post
    Hi all,
    Its just the linkages that need to be renewed. Pretty easy job heres a good diy: 2.0 Shifter Rebuild
    Sometimes if you find you are stuck at the lights shift into second then into first and it usually goes in.
    Jul 2011
    Footscray, VIC
    Worn linkages sounds about right - I shouldn't have assumed an issue with the running gearbox (such as syncros) because then I'd be getting issues whilst the car's in motion - whereas the main issues are occurring when stationary...
    Looks like I should order this kit: Bushing/ Ball only kit - Mk2/3 [SHIFTB2] - $35.00 : USRT, Usually Sideways Rally Team
    Oct 2006
    Yeah anyone of those kits are good and should improve shifting alot. Just letting you know that in some kits they give you an orange thing which most ppl dont replace (you can see the piece in the diy but he doesnt actually change it). Thats because if you undo the bracket to get it off you need to realign your shifter with the proper tool (its easier than it sounds). So i would ignore it unless it is broken. You can see the orange piece in the top left
    Good luck with it!
    Jul 2011
    Footscray, VIC
    Yeah, that grimy brown thing that used to be orange
    I'm all for taking the easy route anyway, will just do the bushings and ball unless the orange thing's shot as well. Might even just palm it off to a mechanic when I get the parts..will let you all know how it goes
    Jun 2011
    Sydney NSW
    When stationary, you will not always be able to select any gear. This is because the baulk rings may not align perfectly with the splines. Sometimes it can help to first select another gear and then come back to selecting 1st. It's like selecting reverse. It sometimes helps to first select another gear and then try and select reverse.
    Jul 2010
    qld
    exact same things happen to me mate, replace all the bushings linkage at the back of the engine bay, its pretty straight forward hardest part is removing the circlip from under the shifter ball mechanism.
    next youl need to replace the ball and socket joint under the shift and also the bushing that goes through the firewall, will need to have ramps and enough space to drop the exhaust/heatshield, am going to attempt this on the weekend hopefully
    Radiators are over rated
    Jul 2011
    Footscray, VIC
    Quote Originally Posted by Glynn. View Post
    Hey Glynn, definitely let us know how it goes after you've done it. I'm still in the process of organising the parts. I'm also not entirely confident about attempting the job at home because I don't have a decent workshop e.g. I don't even have basic stands, let alone ramps (long story short, I was into motorbikes for the past few years and sold all my car stuff). Am planning on getting a good collection of equipment together over the next few months for some more serious DIY, but until then I'm gonna have to tough it out with retail mechnics
    On a side note, I've noticed that it's harder to shift into first when I'm parked on the side of a cambered road, but much easier when the car's on flat surface. I'm guessing the weight attached to the linkages is pulling off to the side, making it harder to line up the gear?
    Jul 2010
    qld
    currently looking for the tool to align the shifter before i attempt to get the ball joint out, you dont really need anything other then basic tools to do the linkages in the engine baytho
