a much needed brake upgrade EBC drilled and slotted 280mm rotors green stuff pads rear dustless pads all up 500
i dont think its a good idea if i run new brakes just before a cruise apparently they need 700 km to properly wear in
also painted my calipers rears still need to be done though
also took my rear wing off as usual it was grey and looked pox so i took info from bboyskidz DIY threadand went and bought some blanking gromets they didnt end up fitting
so i shaved them in half with a sharp blade i used some special polyurethane mastik we make at work and stuck them on the inside of the window,
also used the same stuff to fill the holes left in the window ironically its actually used to stick windscreens in place so its strong stuff
