Welcome aboard!... um to posting! Take a minute to update your profile with your location (although I assume your in Sydney) then come along to one of our meets and say G'DAY!
ABS is going to be a fun one for you if it's anything more than a speed sensor. People talk in thousands to fix the ABS system. In many cases people simply remove the globe and live without it. (I have even heard tell of people hooking up the globe to the air bag light so it lights up when you turn the car on)
Window regs, well, Golf Loon @ Camden GTI can replace them for you on the spot if he has the parts onhand. But then if this is a second card, it's one of those things that may be worth leaving till it breaks.
I think that point one and two are different ends of the spectrum, you either set up for comfort or handling, not so much of both.
The cheaper versions get more travel and comfort the lower they are, otherwise your just pre loading the springs up and getting a harsh(er) ride.
In your case with such a [relatively] small drop in mind you may be best served simply getting your springs reset to sit that little bit lower, failing that a decent cup kit should do nicely although your usually talking more than one inch lower.
Consider a cold air intake rather than a K&N panel, you can look at the BMC CDA or one of it's cheaper alternatives like the one I installed here.
Oh, and nice colour BTW![]()
