Page 357 of 393 FirstFirst ... 257307347355356357358359367 ... LastLast
Results 3,561 to 3,570 of 3924
Thread: MK3 Random Thread
  1. #3561
    Aug 2011
    Quote Originally Posted by stefcio007 View Post
    Has anyone done a window motor swap before? Found the regulator sans motor but my motor is good so would just need to swap.
    Yep as HaydEn said it's just a few torx screws.
    I did the same for one of my rear doors, got the regulator off ebay and swapped in my motor.
    just compare them and you will see some holes with missing screws on the new reg, so just find those on the old and take them out which are the ones holding the motor in.
    Also, loosen and lube up the rubber lined clamp which secures the glass because mine was annoying to remove as the old rubber was completely gripping the glass.
    Liberal amounts of WD40 and jiggle the clamp and glass worked it free.
    Apply WD40 or silicon spray etc onto the new clamp and rubber to assist the glass to back in, but don't completely tighten until you test the power window again and bring the whole window up and down a few times to make sure it settles in the clamp then tighten.
    You can also try and clean up any gunk that has collected in the bottom edge of the door cavity.
    2010 Jetta 125TDi DSG
    1994 Golf VR6 Manual
  2. #3562
    Nov 2015
    My 97 CL has one behind the blanking plate just above the cigarette lighter and next to the ashtray. I assume the 96 Vento has one in the same spot too. However the early Mk3 did not have an OBD2 port.
    1997 Golf CL, 2011 Caddy Life TDI, 2007 Golf TDI, 1996 Vento GL (red), 2008 Skoda Octavia TDI
    1996 Vento GL (white) - RIP
  3. #3563
    Mar 2014
    Bundoora, Victoria
    Quote Originally Posted by doridori View Post
    Yea as Hayden said I don't think I'm obd2 with my 94...
    You need a 409.1 KKL compatible scanner, this is what I use.
  4. #3564
    Jul 2015
    New South Wales
    Quote Originally Posted by feenix74 View Post
    Off the top of my head, you will need from top to bottom of the light fixtures:
    Yellow 12V 21W turn signal bulbs, 2 of
    Clear 12V 21W turn signal bulbs, 2 of (for the reversing lights)
    Red 12V 21/5W brake and tail light (BAY15D), 2 of
    Red 12V 5W Tail light, 2 of (additional tail light)
    Thanks Mate - i'll go get some bulbs today and post the result.
  5. #3565
    Nov 2015
    No problems with the red brake/tail light and the red tail light just take a bit of care with installation, they sit side by side in the fixture and look very similar but the brake/tail light (BAY15D) has an offset bayonet (the two lugs are offset). Do not force it or you will either break the bulb or the fixture.
    Good luck with it.
  6. #3566
    Jul 2015
    New South Wales
    Good luck with it.
    LOL... that explains why i've shattered a bulb (or two) and they weren't fitting correctly... i just went to supercheap and got red and amber globes.
  7. #3567
    Aug 2011
    2 Wins and 1 Fail in the past 2 days:
    WIN 1 - Clockspring from my old steering wheel fixed my airbag light issue (good thing i didn't throw this ripped up piece of crap away)
    WIN 2 - Scored set of 4 Hankook H457 Ventus 2 Concept 2 205/50/15 tires and an alignment at Jax Artarmon for $500 and it falls under the new Hankook promo where i score a $100 gift card so $400 for 4 tires and an alignment is pretty solid especially for this rare sizing!
    FAILLLLL - ANOTHER BROKEN WINDOW REGULATOR (rear left) AS I PULLED INTO WORK AND CLOSED THE WINDOWS
    Still need to get a OBD1 vagcom though to find out what's wrong with my ABS without having to randomly replace sensors...
  8. #3568
    Mar 2014
    Bundoora, Victoria
    I literally bought a new window reg last week. Someone was selling a leftover for $50 (inc. post). Otherwise check out audi-veedub VW Golf MK3 VW Vento LHR Window Regulator NEW | eBay .
    My rear right played up last week and haven't been game enough to open it again until I fix at least the other one. Then I will move on, diagnosing and seeing what's up with the rear right.
    Past - '95 VW Golf MK3 VR6
  9. #3569
    Nov 2015
    I hear you about the VAGCOM to diagnose and clear the ABS fault code on the Vento and figure out what needs fixing. Although in my case it will be an OBDII.
  10. #3570
    Mar 2015
    Any recommendations on brake pads for the 2.0?
    Mk3 2.0. Mk3 VR6 CC. Future Mk2?
