Page 329 of 393 FirstFirst ... 229279319327328329330331339379 ... LastLast
Results 3,281 to 3,290 of 3924
Thread: MK3 Random Thread
  1. #3281
    youll end up replacing your stock struts if you put lowered springs on them
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  2. #3282
    May 2014
    Newcastle, Australia
    Get the fk's, they are a mad deal. The only cheap mk3 coilover worth considering. If you want anything better expect to pay between and extra 400 (cx) or an extra 1000 for anything h&R/kw.
    Sent from my HTC_PN071 using Tapatalk
  3. #3283
    May 2015
    Melbourne, Australia
    Thanks guys. I am gonna buy the fks tomorrow as an early christmas present. Been wanting them for a while.
    Next thing is wheels but that can wait.
    Sent from my SM-N910G using Tapatalk
  4. #3284
    Aug 2011
    really hoping for the stars here, but does anybody have a spare burgundy hatch in Syd with no rust?
    bit of rust on the rear hatch of my vr6 so hoping to find a replacement one
    2010 Jetta 125TDi DSG
    1994 Golf VR6 Manual
  5. #3285
    Mar 2014
    Bundoora, Victoria
    How involved is replacing the rear wheel bearing?
    Should probably just go to mechanic for it.
    Anyone have an estimate?
    Should I do both as a precaution?
    It's getting worryingly loud.
  6. #3286
    Munno Para West Adelaide
    Front wheel bearing? Ivr been quoted $250 for one side on my vento! Thinking of buying a bearing kit and doing it myself
  7. #3287
    Apr 2011
    For a rear wheel bearing you need to remove the caliper, pads and disc. Then you need to press the old bearings out if you keep the old disc but I'd highly recommend replacing it while you're there so you'd press the bearings into the new disc.
    Installation is just the reverse of removal putting the disc onto the rear spindle then a new split pin and caliper/pads on. It's not that difficult I'd give yourself half a day and $250 for new discs and bearings. And yes you would need to do both sides together.
    A mechanic would charge between $500 to $900 as a rough estimate assuming you put new discs and pads on too.
    Sent from my Nexus 5X using Tapatalk
  8. #3288
    Dec 2013
    I saw a beautiful Flamenco dancing girl driving a Mk3 tdi today in Cordoba.
    Spain is literally packed with mk3s, haven't seen more of any other series.
  9. #3289
    Aug 2011
    does anyone know if the 3dr hatch and 5dr hatch share the same bonnet and tailgate?
  10. #3290
    Apr 2011
    Quote Originally Posted by doridori View Post
    Yes they share every panel except the doors.
