Page 376 of 393 FirstFirst ... 276326366374375376377378386 ... LastLast
Results 3,751 to 3,760 of 3924
Thread: MK3 Random Thread
  1. #3751
    Aug 2011
    anyone used one of these leather dye kits you can get on ebay to repair a patchy leather vr6 steering wheel?
    Black Leather Vinyl Steering Wheel Repair KIT VW Golf MK1 MK2 MK3 MK4 MK5 MK6 | eBay
    Mine is losing a bit of colour around the 2 o clock area.
    Leather is still good, just losing colour.
    Or any other suggestions?
    2010 Jetta 125TDi DSG
    1994 Golf VR6 Manual
  2. #3752
    Dec 2013
    Noob question, but just want to confirm that these are the points for lifting with a trolley jack?
    Attached Thumbnails Attached Thumbnails MK3 Random Thread-dsc04379-jpg   MK3 Random Thread-dsc04378-jpg
  3. #3753
    Nov 2015
    Yes they are the jacking points.
    If you have a look at the tire change jack in the boot, you will see that where the jack touches the car is a u-shape which allows the spot welded seam to sit within it without damaging it (see photo below of a later model jack that I quickly googled)
    With the floor jack you have you can get a bit of timber from bunnings with a similar channel in it (usually treated pine used as the border of lattice) and use it to protect the spot welded seam from damage (it looks like somebody has already damaged the seam a bit with a floor jack previously).
    Attached Thumbnails Attached Thumbnails MK3 Random Thread-genuine-vw-polo-seat-ibiza-spare-wheel-jack-lifting-tool-kit-6k0011031b-[2]-7750-p-jpg
    1997 Golf CL, 2011 Caddy Life TDI, 2007 Golf TDI, 1996 Vento GL (red), 2008 Skoda Octavia TDI
    1996 Vento GL (white) - RIP
  4. #3754
    Dec 2013
    Thanks for your help. I'm sure I can put something together. I had a read through some other threads about this for alternative jack points but have such little experience with jacking and under car stuff that I couldn't identify any of them :/
  5. #3755
    May 2010
    When jacking the front, I always jack from the centre of the subframe with a trolley jack.
    Mk IV Golf GTI - BMP - GIAC chip, R32 wheels, KW coilovers, rear swaybar.
    Originally Posted by JoeVR
    I've never been a big fan of rotors, or really Japanese cars in general, so my choice would have to be..... an RX-8.
  6. #3756
    Dec 2013
    Quote Originally Posted by Speed View Post
    I really have no idea what this looks like :/ This is my guess of what I am meant to be looking for. Red dashed line is the subframe, the white circle is roughly the centre point that I should jack from? Next question is thats pretty deep under the car, do I just have to take it slow with the jack lever to start with?
    Attached Thumbnails Attached Thumbnails MK3 Random Thread-subframe-jpg
  7. #3757
    May 2010
    Yes and yes.
    Pump up the jack a bit before sliding under. Takes a few short pumps to get more clearance but.. both front wheels up at the same time
    Just make sure you are only on the subframe and not crushing something else.
  8. #3758
    Nov 2015
    Sorry, I am not sure I help you with that one, been over a decade since I last used a trolley jack on my Mk3.
    Can i ask a dumb question? What are you trying to get under the car to do?
    I have recently invested in a set of ramps so I can get under the Vento (I still have not found the time to do it yet, I have had the ramps for two months). Much safer than using a trolley jack in my opinion. Even after you jack up the car, you should not get under the car without lowering it onto floor stands (positioned on the jacking points that your first photos showed). I apologise if I am trying to teach you to suck eggs.
    If I am changing wheels or bleeding brakes lines or changing brake pads I found just using the wheel jack on the lifting point and doing one wheel at a time was enough for what I wanted to do. In these situations, I was not getting underneath the car at any point and thus minimising the risk.
  9. #3759
    Dec 2013
    Just out of interest. I bought 2 stands and a trolley jack with some money I got for my bday earlier this year.
    Definitely wouldn't work under the car with it only on a jack. I'll just need it down the track for fitting the BBS RS i have sitting in the garage and to do a coolant flush soon and would be easier with it jacked up.
  10. #3760
    Nov 2015
    Cool, hopefully one of the guys with more experience than me will be able to give you some pointers on the best place to position the trolley jack.
