WEAK !!!
U made 55hp more than me, and mine was bone stock lol
I think about 175kw atw should be like the bare minimum u should be making.
Umm Have U Serviced the S/C ?
Replacing your valve stem seals will get u more power and give u better compression.
Check your spark plugs and look for oil, also take the charge pipe off and see how much oil is on the inside of it.
When last did u do a full service ?
Just forgot u only flashed your ecu, guess that's ok.
There's a few things u can do to get more out of it, but ultimately running a standalone will get u best results.
