Results 1 to 9 of 9
Thread: Annoying lights behind the dash
    Jan 2011
    Mt. Waverley, Victoria
    So my lights behind the dash are really dim on the left, so I can't really see the speedo properly at night, I basically have to squint at it (which probably isn't the safest thing to do), so I'm pretty sure that one of them must be out. I'm not sure how many lights there actually are but yeah. Firstly, is there a way to change the lights? (and are there any good guides to doing this?) and secondly, can you change the colour to something other than the crappy green? I mean white would be nice but if not maybe just a brighter blue or something.
    '95 Golf VR6 Colour Concept
    Jun 2009
    Auckland, New Zealand
    You need to pop unscrew and remove the trim surround around the cluster, as well as the air vents either side most likely (makes it easier anyway), then unscrew the cluster, un plug it and pull it out. I think there are like 3-4 little globes that light it up, once you have the cluster out you will be able to see the globes on the back, they just unscrew and pop out.
    The green colouring is from some sort of filter inside the cluster, the bulbs are just regular globes. So to change the colour you would have to somehow modify that, but it wouldn't match the rest of the interior lighting then!
    2016 Golf Alltrack
    Previous:
    Mk3 1.8t
    Sep 2009
    not trying to insult your intelligence, but is the brightness knob turned up? I've been known to over look super simple things -.-
    There are a few DIY's on putting in leds and such of whatever colour you like on the vortex.
    edit: re-read it, if its only one side then yeah, somethings probably gone out
    Jan 2011
    There's a brightness knob? hahaha I dunno haven't checked it
    Jan 2011
    yeah I checked it and it's up full. Alright well I might try out the whole process soon to change the globe if I can be bothered.
    Dec 2006
    Kilsyth, VIC
    At the back of the cluster at the top there are two bulbs:
    See the holes here:
    They are 2 x 2W bulbs (where the rest are 1.1W) that light up the speedo and tacho. It's common for people to use the 1.1W instead of the 2W bulbs which are then no where near as bright. You could hack it up and put in some LED's, something I was considering, but in the end I went the lazy way
    Mar 2011
    Melbourne, Vic
    anyone know where to buy these little bulbs from? also the bulb is in a surround and i cant them to seperate, anyone know if its meant to be there?
    I need 6x 1.1w and 2x 2w
    any help would be apreciated
    Seat Ibiza GTI '95 - Tornado Red - 16" BBS Reps - High Flow exhaust
    Volkswagen Golf GL 1995 - Titanium Grey -- Sold
    Dec 2006
    Kilsyth, VIC
    My local Auto One had them last time I needed some (a while back now). And yes they are a all in one plastic clippy bulb thing.
    Sutherland Shire, Sydney
    Jaycar have them.
