You need to pop unscrew and remove the trim surround around the cluster, as well as the air vents either side most likely (makes it easier anyway), then unscrew the cluster, un plug it and pull it out. I think there are like 3-4 little globes that light it up, once you have the cluster out you will be able to see the globes on the back, they just unscrew and pop out.
The green colouring is from some sort of filter inside the cluster, the bulbs are just regular globes. So to change the colour you would have to somehow modify that, but it wouldn't match the rest of the interior lighting then!
2016 Golf Alltrack
Previous:
Mk3 1.8t
