Results 1 to 10 of 11
Thread: Jacking points
    Oct 2006
    Jacking points
    Wheres the best/most safest point to jack up a car. Will these be ok?
    http://fortuneman.tripod.com/suspens...ages/hr_07.jpg
    Mind you i wont be working under a jack, itll be supported by stands. The manual says never to jack up a subframe but to only use the pinch seams on the sides. Any thoughts as I only have one jack to do both sides at once?
    Need to access the steering rack btw
    Feb 2006
    Camberwell, Victoria
    I have rooted my sills by using jack stands on them!!!
    only use the stock jack on the sills!
    My sills are bent and totally out of shape!
    Be very careful!
    They are suprisingly weak!
    Oct 2006
    sydney
    Quote Originally Posted by peedman
    i usually jack underneith the front subrame in the centre where the gearbox mount is located but if u are doing work on the rack i would recomend you jack up front subframe and put jacks stands underneith the sills that way u can drop the subrame if u need to for working on the rack
    Oct 2006
    Yeah i didnt want to do that coz thats too much work in my mind. So what ive done is jack up one side of the car using a hydralic jack with a block of wood on the pinch seams, then just put two stands on that sill. Holds up fine with the jack still in place for reassurance.
    Seems hard that if you want to have the whole car on stands, you'd need to do some magic since they only recommend to jack the car up in the same spot as were the stands go.
    Camden, Sydney
    I`d jack the car in the middle of the subframe, put stands under the jacking points on the sills. Then if you undoo the subframe, you can lower it down with the jack
    Oct 2006
    Yeah but I only follow the lazy man way Man that steering gaitor is bloody hard to get off and even harder to put back on in a tight spot. Oh well, at least its all fixed and i can say i did it w000t!
    Point Cook, Vic
    what are u doing to the rack out of curiosity?
    FOLLOW US ON FACEBOOK
    Oct 2006
    Changed the inner tie rod Next time ill just pay someone to do it lol.
    Camden, Sydney
    You did bloody well to do it yourself mate.
    I take it you forund a big spanner then
    Oct 2006
    Yeah needed a 32mm spanner! Thanks for showing me how to do it btw my jedi master lol.
Similar Threads
  1. The official MKIV appreciation thread
    By mikinoz in forum Mk4 Golf & Bora and New Beetle
    Last Post: 17-12-2013, 06:40 AM
  2. jacking up a mk 3 - advice
    By golfvr6 in forum Mk3 Golf & Vento
    Last Post: 13-02-2006, 09:22 PM
