Hi guys new here and first real post so please help me out!
Bought a 1997 Golf the other day and have since done a few mods that i will post up later
I now have a problem thoughToo put it bluntly it wont start with the key... I can apply power too the starter and it will start straight away but that's the only way
(Could wire in a relay but would rather try too fix the problem properly first)
I don't have a manual or anything like that yet so i cant really go off fuses or relays,
From what I've read AUS imported 1997 Mk3 CL's (Manual) dont have immobilizers? so i don't really know where too start looking.
The only thing i can think may have done something is that I have replaced the stock radio, but I'm unsure if that would stop it from starting :S
The other thing i noticed is when pushing the car in neutral the radio will cut out until it stops moving :S
Any Help would be amazing!
Regards,
Luke
Might be the ignition switch, search the forums for a DIY, there are 2 ways to fix it as i've done both. If you have an airbag ensure you use the correct procedure in disconnect/connecting.
Matt
