Should be back today, they broke some of the clips on the shifter and Volkswagen lost/misplaced them.
It'll be worth the wait, i might even come on this cruise on friday if i can clock up some k's on it![]()
My car is in at Volksaffair right now getting done![]()
will be vewy interesting how that light flywheel feels! let us aw know!!![]()
I shall, so long as i can get the jump on my old mans new passat from the lights im happy.
ITS BACK!!!!!!!!!!!
now my clutch pedal is as soft as, but the replacement of the shifter bit has improved the shifter feel alot.
car takes off much nicer now and gear changes seem to be smoother, but that could just be the new shifter bit.
i cant just release the clutch a little to roll forward at the lights now which could be a problem, but apart from that there seems to be no noticable downside to the fidanza flywheel![]()
Last edited by BlackVr6ix; 16-05-2007 at 05:10 PM. Reason: Flywheel not clutch......
So the revs dnt drop off fast like losing momentum when u let off? n does it climb the revs faster? these r two things id assume wat would happen wid a lightened fly? dno . . .was it worth it then?
the revs drop off faster than normal but its not as bad as people make it out to be (i do think i have a vaccum leak thou which may not be helping) the revs climb much faster, 1st gear is over in a flash
it was worth every cent![]()
nice![]()
