Results 1 to 10 of 12
Thread: Eagle Eye LED tail light wiring problem
    Mar 2009
    Wagga Wagga
    Hi,
    I have installed Eagle Eye Smoke LED tail lights in my mk3 Golf. They do not work exactle how I would expect them to. The grey and white wire in the luggage compartment had nowhere to plug into on the left tail light set. The wires on the left tail light set are the same as the wires on the right tail light set, with nowhere for the grey and white wire to go. The stock left tail light set had a plug for the extra wire to go.
    The (red) ring of LEDs for the night lights and the top row of (red) brake LEDs work, and work when they are suppose to. The indicators function normally and the reverse lights work. The bottom row of (red) LEDs do not come on with the brakes; instead, only the bottom row of LEDs on the left tail light come on when I turn on the fog lights. I want the reverse lights to come on when I turn on the fog lights, like they do with the stock tail light sets installed. I want the bottom rows of (red) LEDs on both the left and right tail light sets to come on when I brake.
    Has anyone else had this problem and if so how did you fix it? Any assistance with this problem would be much appreciated!
    Attached Thumbnails Attached Thumbnails Eagle Eye LED tail light wiring problem-eagle-eye-tail-light-jpg
    Oct 2006
    The reverse lights never turn on unless ur in reverse gear. You must be thinking of the rear fog lights which would depend on those new headlights, my guess is they dont have em. U should hook the earths to the body and then see if anything else lights up.
    Mar 2009
    Wagga Wagga
    I got mixed up... it wasn't the brown earth, it was the grey and white wire. When the fog light switch is turned on with the stock tail light set installed, the reverse lights are the fog lights. This is normal for a mk3 golf. I want the reverse lights to be the fog lights with the eagle eyes too. Figuring out where to jump the grey and white wire in the eagle eyes should complete the circuit and restore normal functionality. The way they are now is roadworthy and everything. I am just pedantic with my cars and want it to be perfect.
    My NA 2.0L 8v Mk3 Golf is faster than my 174kw twin turbo Supra. V8 utes and over modified Skylines hate being overtaken by old Golfs
    Gosford Central Coast NSW
    Quote Originally Posted by hokenmk3 View Post
    reverse lights coming on with the fog lights is NOT NORMAL on my stock mk3.... rear foglights must be RED by law. reverse lights are white...
    it sounds a bit like your 'stock' settings are not stock.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Jan 2008
    Cremorne, Melbourne
    Hoken, why do you keep deleting your own messages and writing it again?
    If you want to get your thread to the top of the list, just write BUMP..... (you'll need a few fullstops to get it to 10 characters) in a new post.
    Keep in mind people work during the day, you will find your questions will be answered mostly after 6pm EST, once everyone has gone home.
    Just a hint, don't just knock it to the top every 5 mins, people will soon get sick of it and chances are you'll get a warning from the moderators.
    2010 Reflex Silver MK6 Golf GTI
    Sunroof - MDI - Superchip - 19" VMR V710 - Kuhmo Ecsta SPT KU31 - VW Racing Panel Filter
    Mar 2009
    Wagga Wagga
    There was no ulterior motive to deleting my own posts. I was removing abiguity from my messages. Sorry to anybody who interpreted my actions as being rude; I assure you that was not my intention. I have participated in university forums before but am quite new to posting things online. There was probably a more sensible way to do it. I'm still learning.
    Thanks. That does sound sensible. Only the bottom left row of red LEDs come on with the fog lights. The unconnected wire comes out of the left hand side of the car. Do you think jumping it in to the left hand tail light set somewhere could get the right hand bottom LEDs to come on too or is that not logical?
    I have a VR6 wiring diragram (not a 2.0L one) and I can't seem to find the grey and white wire on it anywhere. All the other wires are accounted for. Will I damage things if I start poking around with my multimeter turning things on and off?
    I also have a P-chip for a 91 octane mk3 ECU. Apparently my ECU is 95-96 octane and it won't fit so my P-chip is up for grabs for cheap if anyone knows someone who might want it.
    Sep 2006
    West Sydney
    Welcome to the forums mate. If you make a mistake in your original posts, you can just edit them until you see fit. Deleting then re-writing isn't wrong, but for some users with small screens, they just end up scrolling down and down through nothing which can be annoying.
    Anyway, as I understand, you want your reverse lights (white) to switch ON when you pull your headlight switch to turn on the rear fogs? That's not how it works. As you state here:
    THAT'S the correct way your taillights should work. With the rear fogs, only one side lights up to avoid confusion with your brake lights. In your stock taillights, one side is open for the rear fogs, and the other side is blanked off, i.e. you can't insert a bulb through, even though there's a socket for it on the circuit. As I see it, it's working fine, and I'd leave it as it is to avoid any confusion on the road.
    It seems like the bottom row of LEDs glow when the rear foglight is activated. I reckon you can get the other side to glow if you just insert a bulb into the same rear fog socket as on the other side to get both sides glowing when you activate the rear fog. If you want these LEDs to glow when you brake, I'd think you need to reconfigure the taillight circuit board so that it sends signals to your rear fog bulbs when you brake... I don't know about you but that seems like a daunting task for me!
    Mar 2009
    Wagga Wagga
    Quote Originally Posted by rayray086 View Post
    Thanks. That makes sense. I wonder what was going on with my stock tail lights. I will miss communicating with vehicles behind me who's lights are on high beam... I guess I still can!
    Sep 2006
    West Sydney
    Haha well, what I've done is cut open that blank section off so I've got rear foglights on both sides. Turning them on gives the illusion I'm braking... so yeah, it works as a good tail-gater deterrence
    Dec 2006
    Kilsyth, VIC
    I keep meaning to set up the dual rear fogs on mine too, just for symetry's sake... (Yeah I'm anal like that)
