Originally Posted by
kai_h
Desolder the chip in the ECU, solder in a socket and plug in a new physical chip (or get someone to do it for you)
Mods.
#1 - chip If you can find a cheap one, most don't make a huge difference
#2 - exhaust Always a good idea, can be done cheap (remove suitcase muffler)
#3 - cams Good, but really need supporting mods (Chip ,exhaust, intake) to take full advantage
#4 - Schrick variable geometry intake manifold Damn expensive if you can find one
#5 - suspension and brakes.
#6 - Quaife or Peloquin torsen diff Absolute must if your chasing more power
#7 - bore it out to 2.9, 3.0 or beyond
#8 - get a G-Lader supercharger off an overseas G60 ^_^ Turbo is a better way to go if you have the funds
Some ECU's already have a socket in them from factory, makes it really easy.
1979 Mk1 Golf 2door (Under construction)
1994 Mk3 Golf VR6T, Autronic SM4, GT30r, Peloquin, 288mm Brakes, B&G coilovers
2000 Audi S4 Imola Wagon, Stage 3, J-fonz tune, F21's, ER SMIC, 034 DP's, JHM DTS, JHM Trio Short Shift, 350mm Brembo 6-pot, ABT coilovers, BBS CH, RNS-E, FBSW, Alpha 2.5 cat back
