Results 1 to 8 of 8
Thread: break pads change problem :(
deemoE36 break pads change problem :( 03-12-2006, 03:13 PM
Guest I don't know much about VW's... 03-12-2006, 03:50 PM
wayz Hey DeemoIII Dont know... 03-12-2006, 04:28 PM
Guest Bleed nipple 03-12-2006, 04:36 PM
deemoE36 i think i like ur thinking... 03-12-2006, 05:04 PM
h100vw They defo screw in. The cut... 03-12-2006, 05:11 PM
Oneofthegreats You have to screw them back... 03-12-2006, 05:24 PM
deemoE36 thanks guys, that was the... 03-12-2006, 07:16 PM
    Jun 2006
    Quote Originally Posted by Subie25L
    I don't know much about VW's but some cars have pistons that need to be screwed back. Not sure which way though. No matter how hard you push you will never get them back unless you screw them
    it does have this funny cut-ins, might be that
    tried bleed off, took the bloody caliper off all the way thats how desperate i was
    thnx for the site, thats exactly what i need to do
    im gonna go n try screwing them back
    They defo screw in. The cut out are to fit the windback tool but you can do it with a pair of pointy pliers etc.
    If you have pumped them right out, I would peel back the rubber boot and grip the edge of the piston and turn it using some molegrips or pipe grips. I can hear groans but as long as you get the piston above the rubber then it won't cause any problems.
    You have to screw them back in while keeping pressure on the piston to move it back at the same time. Is a little bit tricky but can be easily done.
    I use some multi grips & a brake piston resetter like this one.
    You could also use one of these
    Or buy a universal kit.
    Jun 2006
    thanks guys, that was the problem
    i used the clamp to keep the preasure on it while skrewing it
    i wouldnt think of it if u guys didnt mantion, first time i heard about skrewing them back in
    cheers
Similar Threads
  1. 95 Ibiza Window Problem
    By VdubDownthePub in forum The Lounge SEAT
    Last Post: 01-03-2007, 03:17 PM
  2. VR6 thermo fan problem
    By Oli in forum Mk3 Golf & Vento
    Last Post: 15-02-2007, 06:28 PM
  3. Replies: 9
    Last Post: 11-02-2007, 05:58 PM
  4. new deck install problem...help
    By deemoE36 in forum Mk3 Golf & Vento
    Last Post: 13-01-2007, 11:01 PM
  5. Brake Pads
    By el_foolio in forum Tuning and Performance (inc ECU upgrades)
    Last Post: 17-06-2005, 11:28 AM
