Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: Another VR6 idle question
    May 2012
    Collaroy
    Hey guys, Just after a few ideas regarding a 94 VR6 (so assuming obd1).
    The idle is rough when starting, jumping about which ive read is a normal thing, it jumps up as high as 1300 and drops super low, also frequently shutting off. This is mostly when starting, but regardless of warm or cold (although obviously more prominent in the mornings/when cold). So far Ive fixed a few things, and theres a few more to go, but would any of these have affected it?
    First, The breather box off the ISV was missing, but recently replaced that and cleaned out the ISV, which was pretty filthy.
    Then the fuse for "engine elektroniks" was blown, so replaced that, but it didn't seem to change much which I thought was strange
    The coolant hoses were replaced recently, but the hoses to the throttle body were not attatched, could this affect idle stability?
    The coolant is also quite low, would this affect the idle in any way? I noticed that once the thermostat opened it seemed to idle steadily on 850ish-rpm
    In short - what the **** can I do to fix my idle!
    Don't suggest a vag scanner unless you've got one that you want to use on this car
    Any help or suggestions much appreciated
    Dec 2008
    Sydney/Canberra
    Look for vacuum leaks, trace the big black line from the brake booster around the engine bay, and the lines that branch off it.
    Look for cracks in the plastic joins, and for split or disconnected hoses.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    May 2012
    Collaroy
    Thanks for the suggestion, I had checked most of them about 3 months ago, but that was before a major service at a mechanics, ill check again, thank you!
    Anyone else with suggestions keep them coming, I want to check everything off!
    Jun 2011
    Isv, tps, vac leak.
    Mar 2014
    Bundoora, Victoria
    1160
    1120
    1120
    1120
    1120
    1120
    1120
    1120
    1160
    1120
    1120
    960
    960
    960
    These are my engine revs from starting the engine until I started moving.
    After some distance my idle speeds while waiting at lights are 760-800 rpm.
    These values are data logged using a reader and my laptop.
    Hope this data can be of use to you in any way. I might add that I get engine code:
    00515 - Camshaft Position (Hall) Sensor (G40) 30-10 - Open or Short to B+ - Intermittent
    Not sure if that's serious but it seems I'm getting similar high idle as you.
    Past - '95 VW Golf MK3 VR6
    May 2012
    Collaroy
    Hmm yeah that seems normal for idle, it seems to rev more and then calm down to a decent level. The TPS and ISV have recently been fixed so I'm assuming they are okay. I checked for vac leaks but couldn't find any. Is it possible the coolant temp sensor can play a part here? I've read a few places that it can affect idle :/
    Dec 2008
    Sydney/Canberra
    Yeah, it's possible.
    A scan may reveal more with that, however.
    '01 Beetle 2.0
    Mar 2011
    Inner West, NSW
    Quote Originally Posted by Umai Naa!! View Post
    I really need to get mine scanned...
    Not only does it idle rough but the mileage per tank is crap with mine - only getting 350km's max per tank and it's all highway driving at 110
    Sep 2010
    Southern Highlands NSW
    Quote Originally Posted by drucejnr View Post
    wow with that kind of consumption you may as well have a VR6 under the hood
    Polo GTI
    T-Roc R
    Tiguan R
    Tiguan 162 Allspace Wolfsburg
    Mar 2011
    Inner West, NSW
    Quote Originally Posted by mrVR6exy View Post
    honestly not sure if youre being sarcastic or not >.> but yeah, it is a VR and when I do city driving I get roughly 250km's to a tank
