Results 1 to 4 of 4
Thread: Help, how can you remove a vw golf seat?
Threaded View
  1. #4
    You may be able to just adjust the linkage if the bush isnt too flogged, i couldnt get reverse. Only made the main 3 bushes as the gear lever linkage one was so buggered I couldn’t get reverse, removed bracket with main bush (has 3 bushes in it) basically just drilled out the rivets holding the bush in place and used a lathe to machine up the bush from some Nylon/Teflon I had. Machined up the other 2 smaller ones so that they were a press fit (by hand) and put them in place once the shaft was in the car, otherwise u cant get the shaft in because the new bushes aren’t flexible like the originals. (was gonna order the units you talked about but needed sooner than 2/3 weeks and i reckon this works better anyway) Shifts beautiful now and I dought will flog out or have that vague feel like the soft originals. Put it all back together lubed with some spray grease (will lube at service times) and all good.
