Results 1 to 10 of 16
Thread: Fixed but still broken.
    Feb 2007
    Just one to check mate. There is a small vacuum hose from the Fuel Pressure Reg on thhe fuel Rail. I have seen regs with a ruptured diaphram sending fuel up this line giving the symptoms you describe. Try cranking the motor with the intake boot removed and see if you get fuel into the intake.
    I think you are taking the right path. Get the car running well in standard trim, then modify.
    Cheers mate, ill give that a go today.
    Quote Originally Posted by velly_16v_cab View Post
    personally if you dont know what your adjusting then take it to someone who does.
    sounds like the car need to be tuned, best get it to your local tuner and set up correctly.
    How am I going to learn anything doing it that way? I might aswell get a new golf then.
    MK1 GLS 3door
    A4 B7 2.0T
    you learn buy asking them how they fixed it and what them.
    better than beating yourself up over it
    Velly
    '91 2.0 8v GTI
    Quote Originally Posted by DubSteve View Post
    I have wood thinking about you
    Feb 2007
    can u suggest a place
    MK1 GLS 3door
    A4 B7 2.0T
    sorry mate i cant, not much need to have the 'lancer of love' tuned up
    i am sure one of the melbourne crew can point you in the right direction
    Velly
    '91 2.0 8v GTI
