Results 1 to 9 of 9
Thread: 8v head build up
    Oct 2005
    Nowra, NSW
    8v head build up
    Sorting out all my gear for my build up. I have a Autotech 270 cam and a mk3 2l head and I'm looking at the following parts from autotech.
    Adjustable All-Alloy Timing Gear
    L/W INTERMEDIATE SHAFT PULLEY
    SPORTTUNED VALVE SPRING SET, 8V
    SPORTTUNED Titanium RETAINER SET, 8V
    the head has a few bent valves so i need to pick up some locally. Plan to get the head ported and polished etc. also but that kinda goes with out saying
    So basically this a good build up? I have a powerchip digi2 chip on the way at the moment as well as a k&n pod setup on the car already, i'm confident it will make some pretty good power. Is this a good setup anything ive missed? besides the supercharger kit that will be coming in the future.
    Is it a full 2 litre motor you are fitting?
    I had an 2E bottom end with an 1800 head when I was in the UK and that rev'd well without a lightweight pulley on the intermediate shaft. Cam gear is a defo though.
    I don't know that you could rev it hard enough to need titanium parts in the head.
    Mine ran to about 6800 with a longer cam than you are running.
    As an 1800 with the same head it pulled 7700 with oversize valves and std retainers.
    Oct 2005
    Nowra, NSW
    its an 1800 but ive got a 2L head, bigger inlet ports.
    edit: 2L head sorry.
    Oct 2005
    Nowra, NSW
    mk3 with a mk3 fuel rail also.
    If I were you, I'll go for a 2.0L block and do up the 1.8 head. Since you already bought all the parts, ignore what I said
    Oct 2005
    Nowra, NSW
    i'm not up for doing an engine change atm don't have the facilities for starters, this should satisfy my power needs for a while yet.
    Feb 2006
    Melborune, VIC
    I have always read that the Mk3 8v heads have a worse flow then a Mk2 GTI head. I am currently building a 2L (AGG) block for my GTI and I plan on using the std EV head as a base for modification.
    I got rid of the AGG head after reading (on clubgti and vwvortex) that it flows worse then the Mk2 GTI heads.
    I am currently running the autotech 270deg cam in my car. It is a very subtle difference, but still noticable.
    What size valves are you going for?
    Oct 2005
    Nowra, NSW
    OK never heard that, I think it depends on what mk2 head also, as i think the rv heads had smaller valves then the euro gti heads.
    a little help on this would be nice, dont want to waste my money
Similar Threads
  1. Advice on 16v head
    By static1800 in forum Tuning and Performance (inc ECU upgrades)
    Last Post: 11-05-2006, 10:56 PM
  2. Head gaskets and rings
    By hiho in forum Diesels
    Last Post: 05-05-2006, 07:04 AM
  3. VR6 head gasket problems?
    By worm in forum Mk3 Golf & Vento
    Last Post: 26-04-2006, 12:51 PM
  4. 16v engines for mk1.... (subject now)...head refitting
    By finemk1 in forum Tuning and Performance (inc ECU upgrades)
    Last Post: 12-12-2005, 03:38 PM
