Just a few tips for those undoing wheel bolts/nuts:
Loosen them whilst the car is still on the ground. That way you alleviate the risk of being to forceful on them whilst the car is jacked up and knocking the car off the jack.
If the bolts/nuts are done up too tight your foot is your friend. Set the wrench at an angle parallel with the road/driveway/flat hard surface you're changing your wheel on and stand on the wrench and apply downward pressure. Unless you're a small child your body mass should be enough to loosen the nut bolt.
For both of the tips above ensure that you have the jack basically sitting snug on the jacking point in case you forget that the car is still on the ground and remove all the bolts/nuts.
If it will fit put your spare wheel underneath the car so if it does fall off the jack it falls onto the tyre instead of onto the ground. This may still cause damage but it will be better than the damage that will be caused by your car underside and/or brakes and wheel hub hitting the ground. When you pull the flat wheel off pull the spare out and swap with the flat tyre.
If you are an RACQ or other equivalent Australian State member than their basic roadside assist should cover callouts to change a tyre if you are unable to (RACQ is a definite). They also should have basic car maintenance courses which are relatively cheap or free which show you how to do things like how to check and top up fluids, check and change tyres and other basic car maintenance (RACQ is a definite). If you haven't ever been shown or don't know how to do these then I would highly recommend it. Basic membership is only around $70 a year. One of the best things you can do if you're a motorist. If you don't have it go online and join now!
Cheers,
Trent
What are you still reading for go and join!
