cheers mate, I used to have both engine covers sticker bombed but the heat destroyed the stickers
http://www.vwwatercooled.com.au/foru...SAM_1900-1.jpg
Printable View
Moar rods arrived today,these ones actually fit :facepalm:
http://www.vwwatercooled.com.au/foru...4dd060eb-3.jpg
I also received this
http://www.vwwatercooled.com.au/foru...5aff7e74-3.jpg
I originally ordered it because my car had been over boosting then misfiring lately. Turned out the pressure source to the n75 was kinked :facepalm: new line and boost is as smooth and stable as ever :D. I'll keep this for the gt2871r install just in case it spikes but I doubt I'll need it. It'll up for sale cheap if I dont need it
And just incase anybody is wondering the difference between the rod sizes. The 20mm are on the right
http://www.vwwatercooled.com.au/foru...2712c0bc-3.jpg
Decided to sticker bomb the front badge today
http://www.vwwatercooled.com.au/foru...9726f9d1-1.jpg
http://www.vwwatercooled.com.au/foru...e8652a51-2.jpg
Loving every bit !!
Looks sick too
Just wondering with the rods you got, do they tell you what torque, to torque the rod bolts down to ?
Thanks
Kay
Thanks mate. Yeah the rods come with a little booklet. It says that the preffered method of tightening the rods is with a stretch gauge and they need to be tightened to 0.006" of stretch. It also states that if you dont have access to a stretch gauge to use a high quality torque wrench and tighten to 50ft/lbs 3 times per bolt using there supplied lubricant
