it looks as tho the avatar option is disabled at the moment.
howcome they dont work anymore?
78 Mk1 Golf
62 beetle still 6 volts
ive noticed that brackies one works still
78 Mk1 Golf
Yes, they're enabled. It's hard when you're logged on as an administrator 'cos very often you don't see what everybody else sees! I looked straight into it and all avatar options are enabled. There shouldn't be a problem (having said that I had to re-upload my own avatar). So I'll log on with an alias and see what happens.
testing one two three
my
edit avatar
link has dissapeared all together
maybe im looking in the wrong place?
78 Mk1 Golf
Im not sure what the problem is, but when you goto "User CP" which is the user control panel the avatars and smilies are OFF but when you post a reply it says the are ON... so im thinking that the OFF in the User CP needs to be turned on *shrugs*
upload failed?
well within the parameters
but it works now anyway
thanks brackie
78 Mk1 Golf
Fixed Yeah... Somewhere in the import the avatar permissions got switched between usergroups. Anyway, it's fixed now (let me know if it doesn't work for you...you may need to re-upload your avatar).
Small problems like this are bound to pop up until the software is completely sussed. It's helluva complex thing 'cos it's so powerful. Coming here from phpBB was like stripping and rebuilding a Holden HR vs a Mk5 Golf!
its working for me now.
