Results 1 to 10 of 15
Thread: What is this noise - Turbo Issues ??
Threaded View
  1. #7
    Gosford Central Coast NSW
    Quote Originally Posted by minsky66 View Post
    They seem to think that it could be the turbo itself, perhaps teh way it was caste or put together or whatever .. and hence saying they can replace it.. only problem is if it is worse than now I get stuck with it that way..
    nope, it doesnt really work that way.
    they are offering to replace it agian because they want to keep you happy - they dont want to do it again after that because there is no other problem apart from the noise, and they certainly can't go replacing good turbo's because its making a whining noise but not causing any specific mechanical issue.
    its very difficult to diagnose noise sources via the internet ( ) however, i have heard turbo diesel cars make many different noises for all kinds of reasons. as transporter stated, it could be a small leak somewhere... or any number of other things.
    small turbo's make plenty of noise at low gas pressure's since they are always doing high rpm, so its no surprise to hear turbo noise at idle with a setup of this kind, providing there is some kind of leak somewhere to let hte noise out.
    some of you are noting that "the turbo comes on at 1750rpm" but this is merely when the engine management closes the vanes and get it really spooling - infact, even with vanes fully open, the turbo is spooling fast enough to make plenty of noise from idle up to that rpm. there is no reason to rule out the turbo as the sourse of the noise, but it is not necessarily the problem itself. a leaky gasket somewhere in the system may well be leaking and producing no visible signs - i've had this myself - you can hear a leak, but yet there is no real mechanical issue or problem, apart form a small gas leak somewhere. small exhaust leaks upstream of mufflers but behind the turbo will also be very noisy (turbo downpipe connection, flexible joints can develop cracks).
    i hope this helps in some way. i would rule out replacing the turbo until (if ever) something serious happens. i dont see any reason to connect the oil deposit issue to the problem either, and i would further offer that there is no place for oil to leak out between the turbo and the engine - only exhaust. oil could possibly leak from the turbo oil return line, or the supply line, however this problem should have been picked up by the service mechanic, if it was the cause.
    HTH
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
