sounds bad mate.
white smoke - steam? or burning oil as you thought. did it loose coolant?
its possible that the turbo has failed massively and started leaking lots of oil into the intake... could definately be the problem.
i hope it doesnt cost you too much. most importantly, i hope you havnt bent a rod due to compression lock if the cylinders got really full.
luck to you,
aydan
