Diesel piston bore clearance
Hello all,
im rebuilding a 1.5 diesel and the bore piston clearance is 4 thou (on the worst cylinder). The workshop manual states that the wear limit is 2.5 thou, however it also states that the valves cant be faced, the seats cut or the head machined and we know that these things can be done. Other manufacturers have wear limits up to 4 thou, (for perkins diesels this is the standard clearance!!) other than perhaps a rattly motor, is there any reason i shouldnt reassemble the motor after honing and re-ringing? (The ring lands measure up ok and it used very little oil prior to disassembly)
Thanks for any advice
Matt
Beige 79 Mk1 GLD White 76 Mk1 LS 3 door
White 68 Alfa 1750 Berlina Champagne 91 Alfa 75
Red 09 9N3 Polo TDI White 2010 Skoda Octavia Combi TDI
