Results 1 to 10 of 12
Thread: Dashboard warning lights on and Faulty codes
    Nov 2014
    Narwee, NSW
    VW Caddy 2008 1.9TDI
    Recently got warning lights on and loss of power one week after serice.
    Dashboard warning lights on and Faulty codes-1-png always on
    Dashboard warning lights on and Faulty codes-2-png blinking.
    Faulty codes: P161B, P161C and P0546.
    I replaced 2#,3# glow plugs then P161B and P161C codes gone.
    Now another faulty code is coming out. It's P2002. DPF might be blocked.
    Dashboard warning lights on and Faulty codes-screenshot_2014-11-09-19-29-49-jpg
    Today I tried to find out the faulty egt sensor.
    Dashboard warning lights on and Faulty codes-dsc_0031-jpgDashboard warning lights on and Faulty codes-dsc_0059-jpgI guess these are the three egt sensors(brown,black and yellow).
    Dashboard warning lights on and Faulty codes-dsc_0051-jpgI took this photo on the top of dpf forward from driver postion . The middle one is Oxygen sensor. The left one is egt sensor (brown). The right one is not egt sensor. It's pressure sensor.
    The other two egt sensors are going deep inside. I can't locate them.
    Could anyone give me any idea which egt sensor is faulty according to faulty code P0546? how to find out the part number? Thanks.
    Annangrove, NSW
    firstly check the engine oil level, if this is too high it will cause the engine and dpf light to come on....be sure the correct oil has been used vw504 and 507 approval .Overfull oil is a possible reason and a easy one to check particularly just after a service.
    Mar 2013
    Brisbane QLD
    Its usually the one with the brown plug that fails......VDUB..
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    May 2006
    Adelaide South Australia
    Quote Originally Posted by volksMuller View Post
    I thought only 507 is approved for engines with a DPF.
    Numerous Mk1 Golf diesels
    Bowral, NSW
    Quote Originally Posted by jets View Post
    This is correct
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
    Nov 2014
    Narwee, NSW
    Thanks for all replies. Checked engine oil level. A littel bit high.
    I unplugged one sensor at a time and scaned faulty codes. Figured out it's the black one.
    Dashboard warning lights on and Faulty codes-screenshot_2014-11-13-14-18-58-jpg the brown sensor
    Dashboard warning lights on and Faulty codes-screenshot_2014-11-13-14-29-28-jpg the yellow sensor
    Dashboard warning lights on and Faulty codes-screenshot_2014-11-13-14-35-26-jpg the black sensor
    When I finished testing and plugged all sensors, something strange happen. All faulty codes were gone.
    Dashboard warning lights on and Faulty codes-3-pngonly this warning light is on. No faulty codes.
    Nov 2014
    Narwee, NSW
    all vw504 and 507 oils are 5w30. would 5w40 be better?
    Feb 2014
    Central Vic
    It's my understanding that thinner oils carry heat away more efficiently. (?)
    Aug 2013
    Quote Originally Posted by snake View Post
    That little light is the DPF regen light
    If it doesn't go out after 10-15mins of keeping the engine speed above about 2000rpm (highway driving) you'll need a manual regen....... but you probably already knew this.
    I Sell Nissans Skodas.
    IT'S HEREEEEE 18' Skoda Octavia 110tsi Manual Hatch | Race Blue | Tech Pack | Luxury Pack | Panoramic Roof | Turini Alloys | Various VCDS Tweaks | RS Spoiler | Mars Bar Holder
    R.I.P; 13' VW Polo 77tsi Comfortline Manual | Candy White | Sport Pack | Pioneer AVH X3800DAB + Clarion Bass Pack
    Sydney/Canberra
    You can't buy a 504 oil or a 507 oil, only 504/507.
    As far as I know, all 504/507-approved oils are 5W30.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
