Originally Posted by
MADHUN
It is common knowledge the first of the BKD engines had frequent issues with head gaskets and cracked heads and that with progressive engine production runs the issues become substantially less frequent.
I have just purchased a 2012 TDi Golf to replace the 2006 TDi Golf that has 275000 kms on the clock.
The 06 was getting to the stage that the cost to keep it on the road, given the mileage I do, exceeded the cost of ownership on the new one; the straw that broke the camels back was the turbo failing, which I replaced in order to sell.
Cut a long story short, when the shop removed the turbo they discovered the coolant flange, part number 038121132g, was completely fornicated and was leaking coolant, albeit slowly, into the exhaust presenting similar symptoms to a cracked head.
A few hundred dollars vs a few thousand.
Before you go ahead and order a head, if you believe it is cracked and leaking coolant, start on the turbo side of the engine and check this and other parts which can leak water to the exhaust, including the coolant flange above and EGR cooler valve.
Very interesting read, i have a GT TDI that has just had its 120k service, my coolant has been slowly dropping the last 6 months and i asked the mechanic to check for leaks from the "Bottle and system" and they could not find anything and flushed and topped up system i think. They made no further suggestions,apart from continuing to check would you recommend anything else, should i be really be concerned do you think?
Current:12 Golf GTD, Mods on order -Bluefin Remap, Mods planned-plenty
Former:08 GT Sport TDI DSG Bluefin, HPA SHS Coilovers,H&R Swaybars with Whiteline Adj Links
