Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 45
Thread: Autospeed article on PD injector timing tune
  1. #21
    Oct 2010
    Quote Originally Posted by benough View Post
    Let me know when you've done it Jarred.
    Given my limited knowledge, I wont be touching it unless I get a technical manual which can explain how to make adjustments to the twin cams I've got one more variable than Julian Edgar haha
    Golf GT Sport TDI
  2. #22
    Jan 2008
    Sunshine Coast
    No way I'd play with that. Diesels have incredibly close piston to head tolerances, and the chances of hitting a valve are far greater than in a petrol car at half the compression. Chances are the adjustment is only a few degrees, but without checking the piston clearances to the valves at the same time with plasticine or similar you can count me out!
    That's one thing I won't be tinkering with!
  3. #23
    Adelaide hills, SA
    Most likely and almost for sure, no matter how much you adjust it, you should be safe, as long as you didn't remove and incorrectly re-fitted timing belt. That means all timing marks were in the correct positions.
    Sent from my HTC Desire using Tapatalk
  4. #24
    after my timing belt my car felt quite sluggish in the top end, the 'powerband' had shifted. (yes... i double checked everything was TDC!) So the next day I advanced my cam timing to the max (which wasn't much from where it was already). Started first time, bang on!
    Now goes like a cut cat and boosts 4psi harder. Win.
  5. #25
    Gosford Central Coast NSW
    If the t-belt stretches over its life slightly, then surely, in theory the cam will retard slightly as the belt wears in. So, I would have thought that as a logical extension, with a brand new timing belt and the crank in the correct position, the adjustment should be somewhere in the middle of the range or towards the retarded end of the adjustment.
    GolfMan - did you advance the cam, or did you actually advance the cam gear? (i.e retard the cam)
    (for instance, in the pic on previous page, the cam closest in view is towards the retarded end of the adjustment)
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  6. #26
    the cam gear of course, the adjustment is all the way forward on the slots. Am going to back it off a smidge today though
  7. #27
    cool.....so it all makes sense.
    '99 A4 Quattro 1.8T
  8. #28
    Oct 2010
    Quote Originally Posted by GoLfMan View Post
    What car are we talking about GolfMan?
    Golf GT Sport TDI
  9. #29
    Quote Originally Posted by jazd View Post
    Polo TDI 8v
  10. #30
    Jan 2010
    North Shore
    Quote Originally Posted by buzuki View Post
    Yeah ive noticed this on most of the 1.9l when ive done timing belts. But ive never touched it.
    A little late in reading this thread.
    If you're not adjusting the cam sprockets to the cams then you're doing it wrong. Go reread ELSA.
