Originally Posted by
gregozedobe
I suggest that if you really want to avoid any accusations regarding chain connections you look into getting proper load rated chain and shackles - they will be more expensive than what you can buy at Bunnings, but they will also be a lot stronger for a similar size. I buy stainless steel ones from a specialist fastener supplier (a winch equipment place may also be able to supply them). They also look a bit less "agricultural".
I don't disagree with anything you say, but the fact is that the Bunnings chain and shackles I used are still far heavier duty than the cr@p that the manufacturer welded onto my trailer or that used on any caravan I have ever seen. That's why it looks a bit "agricultural". At the end of the day, the chain on the trailer will give way first IMHO.
Granite Passat sedan TDI (125kw), DSG, beige leather
Candy White Polo 6R, 66TDI, DSG, no options
