There are two sets of tyre inflation pressures depending on the payload, because the more weight you add to the car, the higher the tyre inflation pressure needs to be. The figures, which are indicated inside the fuel filler flap, represent partial load and full load (diagram should be self explanatory).
Switching between "Partial Load" and "Full Load" on the TPMS means you are just changing the threshold point at which the sensors trigger the warning light, which I believe are based on the figures on the fuel filler flap.
So if the tyres are inflated using the partial load figures, switching to "Full Load" on the TPMS will trigger the alarm, since the partial load figures are less than the full load figures, thus deeming the inflation pressure insufficient.
Can you list the partial and full load pressures for the R36? And does it have any inflation pressures specifically for 235/35 R19 tyres as well? (List these too if present).
- You may not post replies
- You may not edit your posts
Forum Rules
