Results 1 to 10 of 11
Thread: R36 Noob Questions
    Sep 2005
    Maroubra Beach
    R36 Noob Questions
    Loving the R36 only thing is that the manual provided doesnt give all the information i need:
    How do you inflate bolsters on the seats?
    Can you scan a CD/DVD and store it on the hard drive? if yes how do you do this?
    Can you close the auto tailgate with the remote key?
    Is there a function like on the Golf/Jetta's where the rain sensor is used to close the windows if it starts to rain?
    2009 Volkswagen R36 Wagon
    1968 Audi F103 75L Coupe
    1966 Volkswagen Beetle Deluxe
    May 2010
    Melbourne, VIC
    Quote Originally Posted by XXX-1.8T View Post
    I've found the same thing. Thank goodness for VWWC.
    There is a toggle button on the side of the seat, if you look at the memory buttons, and move towards the back of the car, you should see the button for it. It's not labelled though.
    Have you got the RNS510 (satnav)? Or the RCD510 (non-satnav touchscreen, which comes standard with the car)?
    Sep 2005
    Maroubra Beach
    Quote Originally Posted by kleung View Post
    Yep found the toggle thanks for that!
    Why dont they label it?
    Yes i have the factory sat nav touch screen.
    BTW when i turn off esp is it normal for it to flash while its off?
    On my audi the light stays solid when its off.
    Nov 2009
    Sadly yes, its a VW thing and a pain in the bum
    May 2009
    You can only store mp3's on the HDD in the RNS - it won't convert audio CD's into mp3 or whatever to store. I'm pretty sure its in the manual how to transfer stuff across, but basically store whatever MP3's you want to transfer in a folder called Music on the SD card, put in the RNS, select it via the media button, go up the folder tree until you find the Music folder you created, press the button next to it, and a pop up menu should come up - press Copy - and it will ask you where you want to copy the folder to.
    can't close the tailgate with the key - its a safety feature so you don't close it on someone that you can't see if you're standing in the front of the car for example.
    rain sensor to close windows when it starts to rain I think has to be enabled by VAG-COM (or at least it does in my MY09 - MY10's may be different)
    Pete
    MY13 Octavia vRS TDI DSG
    Sep 2005
    Maroubra Beach
    Quote Originally Posted by Pana View Post
    OK Pete but say i have a bunch of MP3's on a CD can I copy from teh CD to the hard drive or is it SD card only?
    May 2009
    yep, you can, but IIRC the transfer rate from CD is a lot slower than from the SD card.
    EDIT: confirmed - found a CD with MP3's on it and started copying it to the HDD - transfer rate is easily twice or even 3 times as slow as transfering it via SD card.
    Pete
    Mar 2010
    Correct, easy to do and works a treat. My favourite R36 VAGCOM mod.
    MY10 Silver R36 Wagon
    VW Classifieds Username - VWC-adrock
    Sep 2010
    Its crazy that book... ive had the car almost 5 months now and i still havent figured out all the little gadgets and intricacies of the car ... took me 2 months to figure out i had a bloody umbrella secretly hidden in the drivers door panel lol
    May 2010
    Melbourne, VIC
    Quote Originally Posted by sanchez View Post
    I probably wouldn't have spotted that if one of the dealers hadn't pointed it out to me while I was shopping.
    Some other cool stuff I've discovered:
    - The parking brake automatically disengages if you try to take off with it still on.
    - The backlight behind the dials and the MFD adjusts its brightness automatically during the day.
    - The seat and mirror positions can be linked to each key individually. It's a bit freaky watching the seats move themselves when you open the door.
