Results 11 to 20 of 21
Thread: Help with 1998 passat ecu/cluster communication vagcom problems
    Mar 2008
    Perth WA
    Quote Originally Posted by Umai Naa!! View Post
    Re-adapt Immobiliser to Engine ECU? Should be able to do that in Engine ECU.
    Good thought.
    So I came across this
    Ross-Tech: VAG-COM: Immobilizer 2 ECU Swapping
    As I have tried a different ecu, which I didn't need, now that I have run a direct k-line wire.
    I have exchanged out the cars ecu for a new one and then the new one out and the original one back in.
    But as I cant communicate with my cluster (The reason I most likely have had to run a k-line wire direct to the ecu) I can't do the procedure...
    Is the K line shorted to ground?
    You can check it with a multimeter.
    Also had a thought do you have a second key? Maybe the little RFID thing has failed?
    Mar 2008
    Perth WA
    When I test the ross-tech it says its fine, ever since I un-plugged the climate control it hasn't had a kline to ground fault.
    No it didn't come with a second key.
    This key when you press the button doesn't do anything, but when I opened it up it looks very simple and looking online I think its meant to have a little globe in it, so the button isn't central locking, just a light.
    I wonder if I can have someone remove the immobilizer
    or could I remove the chip and leave it off the engine ecu board
    like they do in the first half of this clip EDC15P+ Immobiliser Decode/Removal - VW Passat PD130 1.9 TDI - www.ace-ecu.co.uk - YouTube
    or does it have to have the immobilizer turned off with a eprom reader and refitted to the board for the ecu to work...
    or does it have to have the immobilizer turned off with a eprom reader and refitted to the board for the ecu to work...[/QUOTE]
    This bit AFAIK.
    Had an ME7 Polo GTI ECU defeated to use as a demo box.
    With the right gear you can do it with the chip on the board. My knowledge is exhausted now mate. Jimmy is probably the one with the ideas now.
    Mar 2008
    Perth WA
    I have tried removing the immobiliser chip from both boards, still not working, and more faults come up, so I guess the immobiliser needs turning off in the chip.
    I have seen this online, I don't know if its stupid or not
    VAG IMMO Emulator
    Also these guys seem to have an immobiliser disable as an option with there tunes
    B5-B5.5 PASSAT 2.8 30V FLASH - VAG AUTOWERKS
    I guess whats concerning me is whether my cluster is still going to stop it from starting if the immobiliser is turned off, but if the immobiliser is turned off, then I may be able to find a second hand cluster to go into it, as it then wouldn't need to have the matching barrel etc for the immobiliser
    Mar 2008
    Perth WA
    I tried swapping them doesn't work either.
    I put the chips back. cleared the codes, re-adapted the throttle.
    And basically because of the cluster, I had to disconnect the k-line to the ecu and run a new one, if you then try and ad the wire which goes to the cluster to the join the ecu connection drops out. But once the faults are cleared and throttle adaped, if you connect that wire to the join, even though the diagnostic to the ecu drops out, it now starts.... and idles...
    I have cleared all the codes, nothing comes up....
    but if you try and give it throttle it dies.
    If I quickly move the throttle (pumping it) from zero to just before kick down the revs pick up and you can get it upto about 4500rpm if you let it off it idles and try and push the throttle like normal and it goes to die again...
    So its fully warm and still doing it, dunno if fowled plugs, fuel pump pressure low.... I dunno but if I disconnect the cluster wire and scan it all there are no codes coming up...
    Mar 2008
    Perth WA
    I'm going through putting the interior back together.
    But it wont shift from park when the ign on/car running, I can shift from park when the ignition is off
    When you turn the ign on the little red pedal light next to the shifter comes on.
    When you put your foot on the brake the rear brake lights don't come on.
    Normal lights all work.
    Vagcom says under gearbox faults
    00526 Brake light switch-F
    27-00 Implausible signal
    It moved out of park before, as I limped it into the shed
    I have removed the white two pin switch and tried pressing it and pulling it apart it all looks fine, its very simple design.
    Was I meant to adapt the auto ecu? as I just plugged it in...
    Mar 2008
    Perth WA
    on the end of the fuse 13 for brakes the pins had slight white corrosion... so testing the fuse on the end with a multimeter gave a false reading....
    now it goes into gear and up and down the driveway.
    But it runs rough with not a lot of power. fingers crossed fouled plugs.... as there are no faults in the engine ecu
